Posted by BUCK CLAYTON on October 01, 2011 at 20:45:52 from (70.189.97.146):
This tractor has always had a stiff area when starting in one area.Has to have a good battery to crank a complete revolution. Mag. was set on #3 {4 o'clock] instead or #1 and this is how it ran when I got it.Am in process of restoring and have everything off from behind motor to back of tractor.[tank,steering & seat]. Today took all spark plugs out and jacked up rear wheel to match up #1 piston with mag click. Timing advanced 1" past second pully mark.Got mag set only to second mark, but when rolling tire around I still hit this real hard place . Same problem as when starting with battery. What could this resistance be? Trans. and rearend not causing this because with clutch in and cranking with battery ,it did the same. Tractor also has orgional mag. with cable switch and you can rock rotor quarter inch. Rotor does not fit slot in mag shaft. New one does same thing. slot not walowed out. Tried to give all info, sorry for so long. I do need help. Thanks, Buck
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
