You said there was a stiff spot every turn of the WHEEL.
Even in 5th gear, the engine has to rotate several times to make the wheel go around once. That means the stiff spot you're feeling is in the TRANSMISSION, not the engine.
Unless you can crank the engine directly by hand from the front, you can't even confirm there is a "stiff spot" in the engine.
The starter will lug down and struggle to get the cylinders past compression, every 1/2 revolution. That's perfectly NORMAL, if the starter isn't in the best shape, or the battery cables need work.
Get out the hand crank and turn the engine over from the front before you panic and start tearing into the bottom end looking for bad bearings and bent rods.
Today's Featured Article - Tractor Proflie: John Deere Model R - by Staff. The John Deere Model R, the last of the lettered tractors, was the first diesel-powered tractor produced by John Deere with a gasoline starting engine. It was also the first tractor they produced that had an optional steel cab. The photo above shows the tractor w
... [Read Article]
Latest Ad:
[More Ads]
