Check to make sure you have power to all three terminals with the switch on and no power to #1 with the switch off.
With 12 volts applied to the #1 terminal the 10SI should begin to charge at 500 - 700 RPM. That is alternator speed which is about 2 1/2 times faster than engine speed.
If you have power at all three terminals and it is not charging the problem is in the alternator. You can try grounding the little tab inside the D shaped hole to the case. That takes the regulator out of the circuit.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
