Been a while since I filled my C, but drain is centered between axles basically.....square plug use a half inch drive ratchet. Might also drain the PTO/pulley assy. Fill the PTO to level plug, then use remaining in the operator platform just behind clutch. I think I used GL 5 gear oil in mine. Careful with the drain plug, as I think I mentioned that I broke mine out, then had to weld a bolt to it in order to remove. It had never been drained and had at least a gallon of water in the bottom, thus rusting the plug but good.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
