Re: Alternator posts 1 and 2
Posted by equeen on November 05, 2011 at 06:32:36 from (209.102.248.236):
In Reply to: Alternator posts 1 and 2 posted by equeen on November 04, 2011 at 20:24:37:
Thanks for all the great responses.
Before I even attempt to fire it up I shall replace all wiring - initially the wiring necessary to get it running without lights and without alternator (if it will run without alternator wired up).
So, next statement/question...
Solenoid is mounted onto gas tank mounting bracket. 4 post solenoid.
Large right post is wired to battery positive via heavy cable. Post is also wired to ammeter via small wire.
Large left post was apparently cabled to the starter switch on the starter (however the starter switch is missing and will be replaced).
No wire on small left post on solenoid.
Red wire on small right post on solenoid - and another wire is spliced into this wire. The ends of these two wires go....nowhere...they're cut.
Question: Where should a wire off the small left AND/OR small right solenoid post be attached?
(Note: I'm looking at one wiring diagram that doesn't even have a solenoid. The heavy battery cable {positive} is wired to the starter switch on the starter and a smaller wire feeds from the starter switch to the ammeter. I'd certainly like to eliminate the solenoid if it's possible/reasonable.)
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
