Re: Alternator posts 1 and 2
Posted by John T on November 05, 2011 at 06:47:30 from (173.243.181.15):
In Reply to: Re: Alternator posts 1 and 2 posted by equeen on November 05, 2011 at 06:32:36:
If the Solenoid is a Ford type, of course the big main input side is where the big + battery cable attaches plus maybe a 10 or 12 gauge that goes to the ammeter. The other big output side wires to the starter.
On the small terminals one may be labeled S and the other I ??? You wont be using the little I terminal so the one you want is S. If its not labeled, the one you need to use is whichever when hot voltage is applied (solenoid must have frame ground via its mounting bolts) makes the solenoid latch in. Just try a little jump wire with hot battery voltage n see which small terminal makes her latch USE THAT ONE.
But those solenoids are intended for starters that have a stud bolt connection for the solenoid or big cable NOT the starters that use the saddle mount mechanical push to engage start switch. Some guys jury rig the push saddle switch down so its always closed then use the solenoid with a key or push to start switch etc to start the tractor BUT I DONT LIKE THAT SET UP
If it has a good working saddle mount push to start switch you can toss the solenoid, just wire the big battery cable and the small to ammeter wire to the switch and push to start. Or the H amd M and other tractors used a big heavy pedestal mount push to start switch instead of the on starter saddle mount and it wires the same, one side to battery other down to a stud/post on the starter.
John T
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
