Posted by Jimb2 on November 05, 2011 at 17:32:36 from (173.35.57.64):
In Reply to: B-414 Diesel posted by Jake B-414 on November 05, 2011 at 12:13:06:
Hi Jake, had a couple problems where a B-414 Diesel stopped like it was out of fuel. 1) Key came out of shut off control lever on top of injection pump. 2) Ice formed on top of primary fuel filter. 3) Foreign material clogged the filter on the input fuel port of the injection pump. This required removing injection pump and taking to a Diesel Injection pump repair shop.
Have you bled the fuel system, including opening the bleed screws on the injection pump? Also after bleeding the fuel system then loosen a nut on one of the injector lines and then try starting the engine. Be CAREFUL with the high pressure Diesel fuel from the injector lines.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
