Gene, I set the carb linkage as I was taught to: disconnect the governor arm from the carb linkage. Push the governor [throttle] linkage full open. Hold the governor and carb linkage in full open and adjust the turn-buckle on the carb linkage until the two pin holes are in line. On the throttle slop: On the hand lever it is dead from idle until about half-way before the engine responds to the throttle increase. And then it is not a slow increase. It basically will jump from idle to half throttle. I believe it is getting a little worn. I've been around this tractor all my life, and it has always had slop in about a quarter of the throttle lever, which my grandfather told me was about right. I do know that I can take up the play by adding either shims or a longer collar at the end of the throttle rod where it connects to the governor on the mag side. But, will this effect my top end speed?
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
