[qu Yote="scatter"](reply to post at 18:25:32 11/24/11) [/quote]You dont want any play on the input shaft the wobble makes too much slop in the linkage for the hand throttle to work good. You can take off the gov housing carefully then get someone to bore out that hole and install a brass bushing and check the holes where the gov spring goes and its tension. Ihave done a bunch of them they will send them to me and i go thru tham and send them back. Seems like i always get a response that the tractor hans never ran that wiell. You have set the linkage correct from the gov to the carb now you need the housinf redone. You can call me if you would like 319-430-3907
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
