I'm thinking if you can pull well in lower gears, ignition and carburetor has to be right.
Try pulling the tractor (not running ignition off) in road gear. Another H would pull that easy anyway and see if there is too much drag is against the transmission/rear end ??
I'm seeing something similar in a tractor here to include that rear end howl. I just know once I dig in it will add up quickly.
These gentlemen are correct too. As a kid we used to pull hay wagons for miles along hilly roads and we could lay into them pretty good. The H was always a good puller.
I always wanted a step between 4th and 5th but that's going off topic.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
