Posted by Janicholson on December 21, 2011 at 18:10:08 from (96.24.99.126):
In Reply to: H regulator wiring posted by LonM on December 21, 2011 at 17:48:22:
The original system was designed with no reguilator. The operator set the charge rate based on experience. The use of a regulator removes that wire from use all together. One wire goes from the F terminal on the regulator to the F terminal on the Gen. 12ga is correct. One wire goes from the Gen (or ARM) terminal on the reg to the Arm Terminal on the Gen 10Ga is correct. One 10 gauge wire goes to the Bat terminal on the regulator and to the load side of the amp gauge. (side not connected to the Neg bat cable at the Starter Switch) the supply wire to the ignition and lights comes fro the L terminal 10gauge is correct. This scheme allows a little better control of bat charging voltage, than a single wire. Be sure to connect the L terminal to the light switch on the correct terminal, The terminal used for the (old not used) Field circuit is a ground, and will cause smoke if a hot wire is attached to it. The light swithc will have two OFF positions Full CCW and the Next spot will be off. The next position will be Dim lights, then Full CW will be Bright. Jim
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
