You are correct - a manifold switch for battery ignition will have 2 terminals.
If you can't find a 2 wire manifold switch to replace your existing 1 terminal switch, probably the easiest work around is a simple toggle switch mounted on the light bracket. Supply the switch from the "load" side of the ammeter; wire the other switch pole to the ignition coil primary.
In addition I highly recommend also wiring an indicator light to light when the ignition is "on". It will remind you shut off the ignition once the engine is running in diesel mode.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
