Posted by Dan MD on February 26, 2012 at 12:07:29 from (72.160.225.142):
I am in the process of replumbing my entire hydraulic system. I am using the gutted belly reservoir with an IH live pump. Originally I was going to return the oil into the side 1/2" NPT hole that used to be a pressure port. Searching this sight, it sounds like the best results are when the return line enters the bottom of the reservoir. I am mostly going to be using the hydraulics for the 3 point hitch I installed with 2 way cylinders. I currently have 2 questions.
1. I have a 1" NPT hole on the side of the bottom of the tank for the suction line. Is it ok to "T" my return into this same suction line?
2. My tractor had the pressure side of the pump necked down to 1/2" right at the pump outlet instead of using 3/4" line. The valve I got is a 15 gpm valve with 1/2" in and out ports. Am I hurting anything using a 1/2" pressure line. I assume it may add some heat. I don't want to get a different valve.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
