Yes it did. Mine is that way, but it is prone to foaming and continuous flow would probably do it in at some point. I have seen where several people have used the return at the bottom technique and it seems okay as well. I now have a separate 3 spool valve with a filter right after that on the way back to the tank.
For crawlers IH actually just recirculated the oil directly back to the pump. They use a check valve arrangement to keep the lines filled from the reservoir. (Crawlers need to work on steep inclines) Gets just a little warm but these pumps aren't fast enough to worry about heat. If the crawler doesn't heat up with a 82 GPM pump, a 12 GPM SMD is good to go.
If you do run a T down below, have the return line go straight through towards the pump.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
