Posted by Nebraska Kirk on March 22, 2012 at 17:34:29 from (207.91.4.159):
In Reply to: parts removal posted by Marks toy on March 22, 2012 at 15:31:14:
That is one of those things that can be very difficult to remove. You can't put too much pressure on it trying to unscrew it or you could twist it off. Applying too much heat will melt the solder.... Here is what I would do, apply a little heat to it below where it screws into the fuel tank and then spray some penetrating oil on the threads, the heat will help draw the oil into the threads. Put your wrench on it and see if it will move, if you can get it to move a little then just carefully work it back and forth applying, oil all the while, until it unscrews. If you twist it off then just drill out the broken piece until you are close to the threads and then just peal what is left away from the threads.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
