Re: cultivator on b farmall
Posted by mkirsch on April 18, 2012 at 05:41:27 from (64.80.110.75):
In Reply to: cultivator on b farmall posted by jerry standerfer on April 17, 2012 at 10:26:21:
Jerry, a picture is worth 1000 words. It's hard to help without really knowing what you're working with.
We can also take your picture, and draw out what you should do using a paint program... At least those of us with any artistic ability.
In a nutshell, though, you need to identify the "pushrod" that lifts the cultivators, and replace that with a hydraulic cylinder. Sometimes there's room to install the cylinder directly, sometimes not.
You'll probably need to fabricate an anchor point that's attached to the body of the tractor for the cylinder to push off.
You won't need a very large cylinder, or a very long one. If the cultivators lift separately on each side, the ideal situation is TWO cylinders, but you can also rig up some sort of mechanism
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
