Is it easy to crank the motor by hand just after it dies? If not, then you have something seriously awry inside that engine, which will want serious looking into before it destroys something. If yes, then you have other issues. Not sure about the 6 volt system being the problem, because the tractor starts OK after a minute or two. Perhaps check the state of charge in the battery while the engine is running. If there is a charging fault, it may in fact be draining the battery or over charging it, both of which do not help with starting. As to the stopping problem, fuel issues and spark issues are the easiest to sort out and should be checked first if the motor is not tight to turn over by hand. Good luck.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
