Posted by DPittsley on May 28, 2012 at 09:37:21 from (74.71.34.165):
I have a Farmall 240 and am having problems with the hydraulic system. The rear draw bar / three point hitch does go up and down; however it cannot lift any weight. If I lift it with no weight on it then stand on it, it will NOT go down, not unless I bring it down with the lever. I've looked every where to find out how much hydraulic fluid to add without any luck. Also is there a way to check the levels of the fluid? Do I need to bleed the system? If so how? I've added two gallons of trans-hydraulic fluid to the rear end box but this didn't help.
This happened suddenly. One day it worked the next it didn't
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
