Injection pump has built in excess fuel cylinder, but throttle must be set at least 1/3 or more for excess fuel feature to work. Can check with top cover off, should see stop plate move rearward when engine starts and oil pressure comes up, moves forward with no oil pressure. Not common but may be stuck rearward causing hard starting. If it is working OK then hydraulic head is probably worn enough internally that low speed cranking delivery is no longer enough to start engine when hot, but may start when fuel is cold. When it gets bad enough it will never start on it's own but only with a shot of ether but will run once it is started.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
