Posted by LonM on June 10, 2012 at 17:08:17 from (69.165.30.214):
On our magneto-fired H, the ammeter will show a discharge of 3-4 amps for a short (30 sec.) time and then charge at 3-4 amps for the same length of time, then not do either most of the time. Putting it on high charge or regular will not change it any. Running the lights will obviously make it discharge, but it won't "compensate" by charging right after shutting off the lights. This rig has a voltage regulator on it. I am of the opinion that it should not be discharging at all when the lights are off, being as it has a magneto and has no draw on the battery under normal operation. Any input on what is going on here or what I can do to fix this would be appreciated. Thanks, Lon M.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
