First I wonder why do you have a low and high charge switch as well as a voltage regulator? A voltage regulator is meant to do away with the high / low switch arrangement I believe. As you say, the H4 magneto has nothing to do with the charging system.
You should check the brushes and commutator in the generator first. Be sure they are all clean and that the brushes are making good contact. Check that the regulator points are clean. If everything looks good, with no burn contacts or burn marks in the regulator and you still have problems you need to start doing some more technical tests. I think JohnT is the man with the right information for Delco equipment and his trouble shooting list is available on this forum.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
