Posted by John G. Hasler on July 07, 2012 at 19:51:11 from (174.124.42.244):
In Reply to: Re: hey janicholson posted by Janicholson on July 07, 2012 at 14:11:27:
Janicholson writes: > The ground is thus not used (and the well man is > correct, well water is always mineralized and > very conductive right to the water in that > casing. Even plastic casing with entry holes or > a screen section has way enough ""ground"".)
Well drillers are not electricians, let alone electrical engineers.
While potable water is conductive enough to give you a shock it is not conductive enough to provide an adequate safety ground. You could have a dead short from the pump case to one side of the line and not trip the breaker. I have measured 110VAC from the stub sticking out of the top of a well to the casing (steel pipe, not plastic). The gaskets on the pitless adapter insulated it from the casing and rust insulate the pipe where it came through the cap.
Run a green wire up from your pump and connect it to the steel casing or to your system ground. This will provide a solid safety ground and also help protect your pump against lightning.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
