Racing H: Update on the Update
Posted by BruceS. on July 15, 2012 at 13:09:05 from (76.15.9.253):
First of all, thanks for all replies. I just finished doing what everyone suggested: Took off carb fuel bowl and checked throttle plate; not loose and closes with no binding; checked tang on throttle shaft; it is connected to carb and works freely; Adjusted equalzer on bellcrank so that throttle plate would close;all good; checked with disconnected linkage; couldn't see and problems;
checked movement of entire linkage with throttle handle; seems to work fine. Started tractor with throttle handle closed (and also throttle plate)
tractor raced so shut down immediaely. Where do I go from here: Governor lever seems to have "spring " in it, altho not strong. how can tractor run so fast with closed throttle plate unless governor is doing something right after starting. Appreciate any advice.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
