Often time guys get into that governor and think they can increase the rpms of engine by making that link longer. No such luck. The weights and spring tension balance out to control speed. Harder the spring pulls on internal lever, faster engine will run. That link vertical adjustable link is to be adjusted so when gov weights are fully collapsed the throttle plate in carb is fully open, straight up and down. To adjust, take pin out, pull throttle lever wide open, pull up on lever that goes to carb, and then adjust the length of the rod clevis so pin just fit in.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
