Well if yqa just started the tractor the hyd oil was ambient air temp and it will for awhile TILL everything warms up . Normal temp on the oil is around 150 to 180 Normally but add in extra heat and you may have been way over 200 degrees . Your hitch pump may be getting weak . Now with out flow rating the system on a flow rater at operating temp to check gallons per min. and pressure we are shooten in the dark but a weak pump is my guess . Went thru that on our 706 last year was working just fine when i got off and second shift took over two hours after Dusty was running it it started the i don't want to lift anymore . Next morning i put the flow rater on it and i had 10.5 gpm flow at 2050 lbs for a bit and as the fluid temp started up everything started going down FAST . Put a new 12 gpm pump in it and now it is stayen at the 12 gpm at the 2250 that the relief is .
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
