Posted by NolanJae on September 05, 2012 at 05:59:40 from (156.98.127.101):
I pulled the valve cover and adjusted the valves on on my 460, pulled the plugs, checked the points. My 460 has been acting up- rich under power/idle ect. Last couple times ive tried to start her it acts likes its flooded but will start. After the valves and points I left the key on and took off the dist cap and wires and did my compression check 142-147 in all cylinders. While doing the test I left the key on between cylinders. got done with the last cylinder and could smell hot electrical componets. Checked and found that the coil was smelling and hot- so was the resistor next to it. When I removed the cap and wires for the compression test I pulled the wire from the coil and put the cap/wires on the bench. Why did it get hot and is that why I have a miss/ and need to lean the carb? I thought I had crud in the carb or another issue.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
