Posted by jimb2 on September 25, 2012 at 17:08:26 from (99.241.38.122):
In Reply to: Difference posted by rustidiot on September 25, 2012 at 14:09:25:
Hi, 2444 and 444 have the same BD-154 Diesel engine unless you have a rare gas version. The block is slightly different between the 2444 and 444 but the water pump should be same. I looked up in CNH Parts: Water Pump 424,2424,444 and 2444 3042304R91 BEARING, water pump spindle 704216R4 BODY, water pump
B414D,3414,3444 and 7000 Forklift: 3042304R91 BEARING, water pump spindle 704216R4 BODY, water pump
The bearing is usually the part that fails and allows coolant to leak. The bearing can be changed if you have access to a press but otherwise the casting body will break. Years ago when we had B414D,434 and 384, our local IH dealer carried re-manufactured water pumps.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
