Hi, you can place all the clutch and pressure plate on the shaft and bolt the engine to the rear end. If you remove the PTO clutch, make sure to aling the clutch carefully in the center of the pressure plate, before replacing the bolts on the fingers, for that, remove the flywheel, place it on flat surface, put the transmission clutch, the plate, belleville spring, plate, PTO clutch, then presure plate, belleville spring and cover. Aling all of the parts, put 3, 5/16 long bolts and hand tighten to the flywheel. Secure the 3 bolts on the fingers and jam nuts, then adjust the gap. Make sure to adjust the 3 fingers at the same level. The gap for the 3 bolts is .090 inches. Remove the pressure plate, replace the flywheel on the engine crank and finish the job. Bernard le mecano
Hi, yes you can, if you don't change the PTO clutch. If so, make sure to center the PTO clutch in the pressure plate before fastening the finger bolts. Re-gap the 3 bolts to .090 inchs for the PTO plate. Bernard le mecano
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
