An H wouldn't be my choice to run a log spliter. Not enough pressure or volume. I wouldn't even use the larger M pump. The low pressure would necessitate the use of a 5" (even 6") cylinder which will make cycle times very slow.
You might want to consider running a higher volume modern pump off the PTO or belt pulley. Think about 20 GPM at 250 RPM for the PTO and the same volume at 500 RPM with the belt pulley. If you run belts and pulleys, you will have to do the math. There is no point in running the engine at full no load speed. There is plenty of torque and HP.
At 30 GPM, the log spliting task becomes a two man operation unless you have a foot-treadle operated valve.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
