One pretty simple way to get the full voltage to the coil on start is to put a #12 wire from the starter side of the big starter switch (hot when the starter is turning) take this wire to the ballast resistor and put a 4 amp diode on the end so that the electricity can flow to the ignition, but not back to the starter. connect the other end of the diode to the coil side of the ballast resistor. That simple change is equal to the replacement of the starter switch system to add an isolation ignition bypass. If the diode is in backwards, it will melt the ballast resistor. I am not sure I like the idea of the battery voltage dropping that much in 15 seconds. It should stay above 12.5 volts until the starter is engaged. Check cranking voltage (carefully in neutral with a helper) it should be at 10.8 or better while cranking unless it is way cold. Jim
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
