Re: 300 ignition voltage question
Posted by Zachary Hoyt on December 29, 2012 at 15:54:52 from (173.84.189.49):
In Reply to: Re: 300 ignition voltage question posted by Janicholson on December 29, 2012 at 14:27:19:
Thanks for the advice. There is no resistor anymore since I now have a 12V coil, but I think I could do what you said about the diode anyway. It is about 25 to 30 degrees F here today. I did check the battery voltage and it seemed to be dropping into the 10.2-10.6 volt range when cranking for 2 seconds. When cranking for 5 or 6 seconds it dropped momentarily into the 9 range but then bounced back. I checked the terminals on the switch and have 12.4 on the ammeter side and 12.2 on the coil side when the switch is pulled. I do not know if that is normal or not. I put in new points, condenser, cap and rotor in the summer and I think I may replace the points and condenser again to see if that helps, and also I will get a better switch at NAPA. They had a $5 one and a $14 one and I got the cheap one at the time. Thank you very much.
Zach
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
