Posted by Bob M on April 06, 2013 at 12:55:44 from (67.240.171.136):
In Reply to: Stumped posted by Dan Richardson on April 06, 2013 at 10:18:30:
Dan - If running at partial choke stops the loping, problem is a chronic lean condition. A few common causes:
- leak at the carb to manifold flange - leak at the manifold to head gasket - a plugged carburetor port - especially the idle port in the carb throat by just above the throttle plate - float level set too low - broken idle mixture screw (note turning the screw IN makes the mixture richer) - improperly assembled carburetor
Also do as Bouncer suggests: Check for good fuel flow into the carburetor. Remove the drain plug or cock from the bottom of the bowl - it should flow a solid stream of gas. If gas just dribbles out there's a restriction)
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
