Posted by Bob M on April 06, 2013 at 13:58:14 from (67.240.171.136):
In Reply to: Farmall 300 gas leak posted by Evan Mellott from Iowa on April 06, 2013 at 13:17:05:
Sounds like there's 2 problems here:
1 - Fuel dripping from the carb and from the sediment bulb shutoff handle says the sediment bulb is worn out. Replacing with complete new bulb assembly will cure that.
2 - Fuel coming from the bottom of the carb and between the bowl and air horn castings means the float needle valve is not shutting off when the bowl is full. Could be junk caught in the needle valve, a worn out needle, float level set to high, or a rubbing or gas-logged float. And gas leaking around the carb gasket means either the screws that hold the two halves together are loose, the gasket is bad, or (unlikely) there's a crack in the upper part of the bowl casting.
Today's Featured Article - Chores - by Frank Young. The ceaseless passing of time! It is at once our friend and our enemy. It measures our progress and it makes us old. Like most features of our life, few things are all good or all bad, and most such judgments depend on our own perspective or viewpoint. In our particular hobby, we enjoy the nostalgic return to the days of our youth as we recreate many of the scenes that took place on the family farm that served as the stage for the first few acts of the play that is our live
... [Read Article]
Latest Ad:
[More Ads]
