Posted by John T on April 14, 2013 at 20:08:23 from (216.249.82.117):
In Reply to: farmall c generator posted by burnsg2003 on April 14, 2013 at 18:16:27:
I agree with my sparky buddies, check the belt and its tension,,,,,,,Polarize once more just to be safe,,,,,,Insure the genny has a good frame ground (maybe run a ground jumper from gennys case to batterys grounded post),,,,,Try dead grounding the gennys FLD post at fast RPM n see if she charges then??? If so but NOT otherwise, the VR may not be well grounded or is bad or mis adjusted or the wires bad from FLD on genny to FLD on VR.....
Sounds like you already tried my troubleshooting procedure right?? Its Para 5 shows how to tell if non charging is a Genny versus a VR problem and has a Motor Test for the genny itself
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
