Posted by tractorboy 27 on April 21, 2013 at 08:33:08 from (75.156.113.67):
In Reply to: HELP! posted by Pavel on April 20, 2013 at 11:56:34:
you have to remove the gas tank, belt pully, starter, linkage rods,disconnect guages, etc and the cover will come off without splitting the tractor in two. you cant split the tractor in two without doing the previous as the bolts that hold the two halves together are inside the body. Have you removed the inspection plate from the bottom of the tractor and taken a look inside to see what is the problem. I had a mouse nest and wasp nest inside mine that was preventing movement of the fingers on the pressure plate
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
