Posted by caseman-d on May 10, 2013 at 08:31:51 from (67.142.174.21):
In Reply to: Gas in oil pan posted by Ihcrazy1 on May 07, 2013 at 05:01:52:
A 350 should be gravity flow, it has a updraft carb,gas should run out of the carb. before it can get to the governor tube (which I have a hard time believing). Only way for the gas to get in the oil is running to rich, it will wash the cylinder walls down and cause it to burn oil. Running with bad plugs. Check plugs to see if they are wet or extremely black. Another thing also if your float is set to high you may not be able to lean it out enough. How much overfull is your oil level? Do you run it long enough to get it up to operating temp. Tractor needs to get to operating temp to preform right. Hope this helps. caseman-d
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
