Posted by rustyfarmall on May 10, 2013 at 10:53:00 from (216.248.71.226):
In Reply to: Gas in oil pan posted by caseman-d on May 10, 2013 at 08:31:51:
It is true the carburetor is gravity fed. It is also true that if the float valve is malfunctioning, the carburetor will flood, and yes, the excess gasoline will exit at the intake, but if there is a good, tight connection between the carb and air intake hose, the gasoline will proceed to fill up the intake pipe, but only to a point where it will then be as high in the carburetor as it is in the intake, and then the excess gasoline WILL exit through the governor tube and go directly into the oil pan. The laws of physics do apply here.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
