Posted by wayne in mn on May 18, 2013 at 19:20:19 from (71.8.147.153):
In Reply to: Compression on 300 posted by DKRod on May 18, 2013 at 19:04:45:
Check the valves for proper clearance. Next: get a compression tester and, 1.test for compression with throttle set wide open, 2.squirt about a teaspoon of motor oil into each spark plug opening, 3.spin the engine a few times, and then 4.re-test the compression. If the test results increase markedly with the addition of oil, the engine likely needs an overhaul.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
