If you have the hitch using a lift arm pivot bolted to the transmission top cover and a front hydraulic cylinder and a rear one. You need a working front cylinder and the following pins removed. Front rockshaft hole so front of hitch will go up and down when operating the front cylinder, pin at top of the lift rod, 2 pins below the lift balls near the prong sockets. From the center of the pto shaft to the inside of the right rear tire set distance at. 14 inch plow 26.5 inches, 16 inch plow 28.5. For the hitch with handle on the left side. Remove pins from the 2 sockets so they can turn up. Pin near the lower end of the hydraulic cylinder that keeps the lift arms from floating up. Move pin in the swing limiter so hitch will swing. Adjust handle to notches as needed when you start plowing. Keep pin in the left lift link and the collar on the leveling crank in the top position. If I remember correct the big prongs are 1/4 inch taller than the small ones. Can measure tomorrow to double check if needed.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
