300U - pulling from a fast hitch
Posted by Dave H (MI) on November 04, 2013 at 06:41:19 from (173.99.197.241):
It's been a sad thing indeed but the Emerald Ash Borer has left my woodlot bereft of Ash trees...I suspect permanently. I have several pretty large trees healed over into surviving oaks and hickories. Thinking the 300U has the guts to get these pulled down but it has a FH and I would be pulling from a drawbar inserted into the lift arms. Now I know enough not to pull from a 3 pt hitch but the FH is attached up under the transmission and not to the rear axle...more like a traditional drawbar. If I keep the hitch lowered will I be reasonably save from going over backwards if a log hangs up or should I pull from a clevis on the front of the tractor? Not dragging the logs, just pulling them down off the trees they are leaning against.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19 ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
