Re: 300U - pulling from a fast hitch
Posted by NoNewParts on November 04, 2013 at 07:29:20 from (67.240.141.151):
In Reply to: 300U - pulling from a fast hitch posted by Dave H (MI) on November 04, 2013 at 06:41:19:
like said, pulling from the fast hitch is ok, designed for it.
But, even a small tree will toss around/up a tractor like
a toy if it goes wrong.
Long chain, cable,
chain a pulley or old rim to the base of a standing tree.
tractor, chain thru rim, then to leaner.
Then you are pulling level and a 'pull back' will just pull you toward the tree base.
And like all rear lift tractors, putting on a implement like a rear blade and pulling from that with it barely dragging the ground is always safer.
and with all that said, I don't do it at all anymore after some
close calls.
I use long chains, winches, come-alongs now.
And at the first movement of the tree, I RUN, away from the tree, chains, cables, everything :D
This post was edited by NoNewParts at 07:46:10 11/04/13 2 times.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th ... [Read Article]
Latest Ad: Sell 1958 Hi-Altitude Massey Fergerson tractor, original condition. three point hitch pto engine, Runs well, photos available upon request [More Ads]
