Posted by Farmer Matt on December 16, 2013 at 07:30:46 from (12.48.16.2):
My tractor fixing expertise spans about 2 months and I could really use some help as I am out of ideas. I am dying to hear my great-grandfathers H purr once again...
So far I have removed the head to clean up the sludge and free up 2 stuck valves. The pistons had a good amount of carbon build up, appears to have burned oil. Engine internals 'looked' okay and reassembled.
Carb was gummed up bad, so I got a complete rebuild kit & cleaned everything out. I have the governor & carb linked up correctly as the throttle plate is wide open.
New coil, points, condenser, cap, rotor, plugs and wires and I get good bluish spark on all 4 plugs.
After playing with the distributor, I realized my timing was out of whack. So I put #1 to TDC, lined up the notch on the pulley, then got the distributor rotor to line up with corresponding #1 point under the distributor cap. Firing order 1-3-4-2. I think I did that right?
I go to start the H and...nothing. Ok, so I put some starting fluid in thru the spark plug holes...not even a cough. I do the same with a little gas...not even a cough.
Did I do my timing wrong?
Turning the hand crank takes a fair amount of effort, so I know there is some compression to suck fuel thru the carb.
I am out of ideas....Sorry for the wordiness, just trying to be through. THANKS!!!
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
