Posted by Tom Fleming on December 16, 2013 at 16:09:51 from (173.233.18.197):
In Reply to: '42 H Just Won't Start posted by Farmer Matt on December 16, 2013 at 07:30:46:
ok, some good advice has already been posted here. An engine needs 4 things to run: fuel, air, spark, compression
The only thing I am going to do is put it in order like a check list:
1.) Make sure valves are set at correct, COLD lash.
2.) Set timing manually. As already indicated, get #1 TDC for the compression stroke. As indicated, install distributor firing at #1.
3.) Make sure plugs and points are properly gapped.
4.) Wires should be copper core, with bright, clean connections. Firing order 1,3,4,2, going clockwise from #1 post which is at approximately 2 o'clock on the cap.
5.) Turn on fuel, and make sure carb is getting plenty of fuel flow.
6.) Iidle air adjustment should be closed tight, then out 1 1/2 turns. Main jet, same, bottom out then at least 2 to 3 turns out.
7.) Air cleaner should be clear and clean. Fresh oil.
8.) Open and consume beverage of your choice, review and recheck previous 7 steps.
7.) start it. Consume 2nd beverage whiling enjoying the sound of your Grandpa's running tractor.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
