Re: 1086 3 point hitch
Posted by Jim Naden on January 13, 2014 at 00:02:21 from (70.198.66.172):
In Reply to: 1086 3 point hitch posted by gbs on January 12, 2014 at 13:36:05:
gbs said: (quoted from post at 14:36:05 01/12/14) i removed the top link bracket to see how much piston seal leakage it had,as suspected the piston is seal leaking ,question is there are 3 more small streams of fluid coming from the right rear of the cylinder are these normal,if not i will try to locate their source,also does the lift use the same pump as the remotes
If you had it running while inspecting the cylinder leakage then yes, some oil running down the right side is normal.
That said, when you have the cylinder out to replace the seal it is a good idea to replace all the sealing rings and o-rings that seal tha draft control valve to the cylinder housing.
It's also not uncommon for the draft control valve bolts to loosen, most common is the one with the spring anchor.
Make sure you update the piston from an o-ring to the lip seal.
This post was edited by Jim Naden at 00:04:19 01/13/14.
Today's Featured Article - A City Guy's First Tractor - by Fred Hambrecht. After living in apartments in Atlanta for more years than I care to remember, the wife and I decided to move to the country. Humming "Green Acres is the place for me..." we purchased a 29 acre tract about 60 miles south of Atlanta. Next came the house, I could talk about that ordeal for another two weeks... But, I want to talk about my tractor! We didn't even own a lawnmower, and all of a sudden we had enough grass to feed all the starving children of the bovine world. Naturally, I talked ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
