FARMALL 460 Crankshaft Main Thrust Bearing
Posted by JC3 on February 02, 2014 at 09:17:02 from (205.243.121.118):
I ordered main crank shaft and rod bearings for my 460 here. The number 3 main crankshaft bearing has a wider side flange than the one I took out and I am not able to get the new bearing to slide in around the crank. The number 1,2 and four go in fine. I checked my clearance with plastigage on the new bearings at .oo2". The bearings I took out are standard size so that"s what I ordered back. I did see in the I&T manual that apparently they changed the thrust bearing surface from 3 3/4" to 4"on later models but the diameter on the new bearing and the old bearing are the same. The only thing I see different is the side flange. My question is, why does the thrust bearing not fit? Thank You.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
