Posted by mazemeister on March 14, 2014 at 15:02:39 from (173.3.242.74):
In Reply to: 1486 range stuck posted by idahofarmer on March 14, 2014 at 14:43:51:
pull up the floor mat and remove the rectangular plate of steel so you can get at the top of the trans. the range trans is back under the seat so you got to kinda reach back there with something, but there are 2 shafts w/ arms on the top. if you wiggle the range lever, you'll see which two it tries to move. what you need to do is put the lever in neutral but over toward rev/park, then reach back there to the high/low shaft and put it manually in neutral. then you're all set.
it helps to make sure you're completely stopped before taking it out of gear and make sure you shift fore/back to neutral, side to side as necessary, then fore/back to what you want, instead of doing more of a U shaped motion.
Today's Featured Article - The 8N and the Fox - by Zane Sherman. Dec. 13 1998, Renfroe, Alabama. Last niht I dreamed about the day that I plowed the field of about 10 acres over on what Jimmy and Dandy called the Ledbetter field. I was driving the 1948 8N Ford tractor that Jimmy bought in 48 new This was prebably in about 1951 and maybe even befor the house was built. This would have made me to be about16 years old and I drove the tractor for nothing and would have paid to drive it if I had had any money which I didn't, but neit
... [Read Article]
Latest Ad:
[More Ads]
