The issue is voltage to the ignition system while cranking. SMTA tractors need high CCA batteries 800 will do. They also need heavy battery cables because they are long, and the engine is tough to crank, If it is cold out it can draw 550 amps. The cables need to be 00gauge wire which is about 3/8 of an inch of wire diameter, not including insulation. The connections need to be soldered on and shrink tube sealed to assure tight and high amp conductivity. The ground should connect to the starter motor mounting bolt clean and shiny, then painted if needed. Welding cable, or OTR truck material is best for construction. Jim
Today's Featured Article - New Life for an Old Allis - by Tyler Woods. My friend Jon, has an old '39 Allis Chalmers B. He thought it a marginal tractor that had long since served its time. She smoked terribly and never had much power but he couldn't afford another so he was limping along with what he had. Jon's Allis has a small front loader and though it doesn't carry much, it serves his needs. It was the hard starting and low power that made him think it was time to replace the old girl. Jon called me to help him discover why his tractor wouldn't start
... [Read Article]
Latest Ad:
[More Ads]
