Posted by wicksfield on May 18, 2014 at 03:53:40 from (67.236.246.150):
Got a buddy with a beautiful restored SMTA but it starts hard. We feel it"s an ignition problem. Here"s the symptoms:
1. Ignition on, test light bright on the battery side of the coil and on the distributor side of the coil while holding the points open.
2. When cranking the engine, the test light on the distributor side of the coil is dim and of course flickers when the points open and close.
3. The engine only starts when the starter switch is released and the engine makes one last revolution. That would be the time when the test light becomes bright again on the distributor side of the coil.
Can you guys help us out? Thanks in advance for your response.
Today's Featured Article - George's Fordson Major - by Anthony West (UK). This is a bit of a technical info to add on to the article about George's Major in the "A Towny Goes Plowing" article. George bought his Major from a an implement sale about 18 years ago for £200.00. There is no known history regarding its origins or what service it had done, but the following work was undertaken by Harold alone to bring it up to show standard. From the engine number, it was found that the major was produced late 19
... [Read Article]
Latest Ad:
Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor
[More Ads]
