Others have identified the cause being that the starter is drawing down the battery supply so there is low voltage at the coil.
Weak battery or bad connections can be the cause.
One other possibility. Is this 6 or 12 volt system. I've seen a couple of tractors with 12 volt conversion kits give the same problem. The reason was that the supplied resistor for the coil was too high resistance. Should be 1.5 to 2 ohms, on one of mine it was 5+ ohms.
On mine I replaced the 6 volt coil with NAPA IC14SB -12 volt no resistor required- and eliminated the resistor. That cured the problem.
Today's Featured Article - Harvestin Hay: The Early Years (Part 2) - by Pat Browning. The summer of 1950 was the start of a new era in farming for our family. I was thirteen, and Kathy (my oldest sister) was seven. At this age, I believed tractor farming was the only way, hot stuff -- and given a chance I probably would have used the tractor, Dad's first, a 1936 Model "A" John Deere, to go bring in the cows! And I think Dad was ready for some automation too. And so it was that we acquired a good, used J. I. Case, wire tie hay baler. In addition to a person to drive th
... [Read Article]
Latest Ad:
[More Ads]
