Injector pump problems international 454
Posted by MAH on May 31, 2014 at 05:27:49 from (71.83.74.137):
Hello, I have international 454 that has always cranked and run real well. I started getting diesel in the crankcase so I took it off and had seals put in the pump. I put the pump back on and now it won't start. I talked to someone and they said might need to take pump off and turn pump revolution. Also, the guy that worked on my pump said that the two lines one from filter and the other on top of pump. He said that you need to make sure you put the bolts that hold the lines are put in the same place they come out. One of the bolts has a bigger hole up through the bottom than the other. Can someone tell me which one goes where? In case I have them mixed up.
Today's Featured Article - Tractor Hydraulics - The Basics - by Curtis Von Fange. Hydraulics was one of the greatest inventions for helping man compound the work he can do. It’s amazing how a little floor jack can lift tons and tons of weight with just the flick of a handle. What’s even more amazing is that all the principals of hydraulic theory can be wrapped up in such a small package. This same package applies to any hydraulic system from the largest bulldozer to the oldest and smallest tractor. This short series will take a look at the basic layout of a simple hydraul ... [Read Article]
Latest Ad: Oliver 550 Diesel runs like a watch three point hitch pto engine gone threw about two hundred hours ago nice clean tractor [More Ads]
